I would like to count how many child rows under each parent for a SwfTable. But it cannot recognise the child row under the parent row.
Ammar
Hi Ammar,
Thanks for your Inputs, but here the exact problem is I want to select particular row in the 3rd band. The condition is based on colum text. First I want to search for 1st band and I have to expand, then I want to search for 2nd band then expand then i have to search for 3rd band then I want to select that particular row. The searching is based on particular column.
I don't want to hard code any row or column, I want to pass the row name and column name from datasheet. It amy be 1st row , 2nd row or 10th row, It depends on my requirement.
