I tried to Access a SharePoint site through SharePlus lite using window authentication. I can't connect to the site, following is the trace log:
USER_COMMENT=ANDROID_VERSION=4.4.4APP_VERSION_NAME=2.0.478APP_VERSION_CODE=478USER_CRASH_DATE=2014-12-08T10:43:09.000-05:00BRAND=samsungPHONE_MODEL=SM-N900PCUSTOM_DATA=STACK_TRACE=com.infragistics.shareplus.a.h: SharePlus can't process the received data.at com.infragistics.shareplus.a.a.j.c(SourceFile:121)at com.infragistics.shareplus.a.a.j.a(SourceFile:101)at com.infragistics.shareplus.ui.n.a(SourceFile:396)at com.infragistics.shareplus.ui.n.a(SourceFile:391)at com.infragistics.shareplus.a.d.doInBackground(SourceFile:25)at android.os.AsyncTask$2.call(AsyncTask.java:288)at java.util.concurrent.FutureTask.run(FutureTask.java:237)at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)at java.lang.Thread.run(Thread.java:841)Caused by: com.infragistics.shareplus.f.d: SharePlus can't process the received data.at com.infragistics.a.a.d.a(SourceFile:90)at com.infragistics.a.a.b.a(SourceFile:44)at com.infragistics.a.f.a(SourceFile:62)at com.infragistics.shareplus.f.c.e.a(SourceFile:31)at com.infragistics.shareplus.f.c.f.a(SourceFile:101)at com.infragistics.shareplus.f.c.f.e(SourceFile:86)at com.infragistics.shareplus.f.c.f.a(SourceFile:65)at com.infragistics.shareplus.f.c.l.a(SourceFile:477)at com.infragistics.shareplus.f.c.l.a(SourceFile:124)at com.infragistics.shareplus.a.a.j.c(SourceFile:119)... 10 moreCaused by: org.xmlpull.v1.XmlPullParserException: Expected a quoted string (position:DOCDECL @1:55 in java.io.InputStreamReader@42d2dc98) at org.kxml2.io.KXmlParser.readQuotedId(KXmlParser.java:664)at org.kxml2.io.KXmlParser.readExternalId(KXmlParser.java:643)at org.kxml2.io.KXmlParser.readDoctype(KXmlParser.java:585)at org.kxml2.io.KXmlParser.next(KXmlParser.java:418)at org.kxml2.io.KXmlParser.next(KXmlParser.java:310)at com.infragistics.shareplus.h.g.e(SourceFile:76)at com.infragistics.shareplus.h.g.a(SourceFile:32)at com.infragistics.shareplus.h.g.a(SourceFile:23)at com.infragistics.a.a.d.a(SourceFile:24)at com.infragistics.shareplus.f.d.q.i(SourceFile:35)at com.infragistics.shareplus.f.d.q.h(SourceFile:16)at com.infragistics.a.a.d.a(SourceFile:88)... 19 morecom.infragistics.shareplus.f.d: SharePlus can't process the received data.at com.infragistics.a.a.d.a(SourceFile:90)at com.infragistics.a.a.b.a(SourceFile:44)at com.infragistics.a.f.a(SourceFile:62)at com.infragistics.shareplus.f.c.e.a(SourceFile:31)at com.infragistics.shareplus.f.c.f.a(SourceFile:101)at com.infragistics.shareplus.f.c.f.e(SourceFile:86)at com.infragistics.shareplus.f.c.f.a(SourceFile:65)at com.infragistics.shareplus.f.c.l.a(SourceFile:477)at com.infragistics.shareplus.f.c.l.a(SourceFile:124)at com.infragistics.shareplus.a.a.j.c(SourceFile:119)at com.infragistics.shareplus.a.a.j.a(SourceFile:101)at com.infragistics.shareplus.ui.n.a(SourceFile:396)at com.infragistics.shareplus.ui.n.a(SourceFile:391)at com.infragistics.shareplus.a.d.doInBackground(SourceFile:25)at android.os.AsyncTask$2.call(AsyncTask.java:288)at java.util.concurrent.FutureTask.run(FutureTask.java:237)at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)at java.lang.Thread.run(Thread.java:841)Caused by: org.xmlpull.v1.XmlPullParserException: Expected a quoted string (position:DOCDECL @1:55 in java.io.InputStreamReader@42d2dc98) at org.kxml2.io.KXmlParser.readQuotedId(KXmlParser.java:664)at org.kxml2.io.KXmlParser.readExternalId(KXmlParser.java:643)at org.kxml2.io.KXmlParser.readDoctype(KXmlParser.java:585)at org.kxml2.io.KXmlParser.next(KXmlParser.java:418)at org.kxml2.io.KXmlParser.next(KXmlParser.java:310)at com.infragistics.shareplus.h.g.e(SourceFile:76)at com.infragistics.shareplus.h.g.a(SourceFile:32)at com.infragistics.shareplus.h.g.a(SourceFile:23)at com.infragistics.a.a.d.a(SourceFile:24)at com.infragistics.shareplus.f.d.q.i(SourceFile:35)at com.infragistics.shareplus.f.d.q.h(SourceFile:16)at com.infragistics.a.a.d.a(SourceFile:88)... 19 moreorg.xmlpull.v1.XmlPullParserException: Expected a quoted string (position:DOCDECL @1:55 in java.io.InputStreamReader@42d2dc98) at org.kxml2.io.KXmlParser.readQuotedId(KXmlParser.java:664)at org.kxml2.io.KXmlParser.readExternalId(KXmlParser.java:643)at org.kxml2.io.KXmlParser.readDoctype(KXmlParser.java:585)at org.kxml2.io.KXmlParser.next(KXmlParser.java:418)at org.kxml2.io.KXmlParser.next(KXmlParser.java:310)at com.infragistics.shareplus.h.g.e(SourceFile:76)at com.infragistics.shareplus.h.g.a(SourceFile:32)at com.infragistics.shareplus.h.g.a(SourceFile:23)at com.infragistics.a.a.d.a(SourceFile:24)at com.infragistics.shareplus.f.d.q.i(SourceFile:35)at com.infragistics.shareplus.f.d.q.h(SourceFile:16)at com.infragistics.a.a.d.a(SourceFile:88)at com.infragistics.a.a.b.a(SourceFile:44)at com.infragistics.a.f.a(SourceFile:62)at com.infragistics.shareplus.f.c.e.a(SourceFile:31)at com.infragistics.shareplus.f.c.f.a(SourceFile:101)at com.infragistics.shareplus.f.c.f.e(SourceFile:86)at com.infragistics.shareplus.f.c.f.a(SourceFile:65)at com.infragistics.shareplus.f.c.l.a(SourceFile:477)at com.infragistics.shareplus.f.c.l.a(SourceFile:124)at com.infragistics.shareplus.a.a.j.c(SourceFile:119)at com.infragistics.shareplus.a.a.j.a(SourceFile:101)at com.infragistics.shareplus.ui.n.a(SourceFile:396)at com.infragistics.shareplus.ui.n.a(SourceFile:391)at com.infragistics.shareplus.a.d.doInBackground(SourceFile:25)at android.os.AsyncTask$2.call(AsyncTask.java:288)at java.util.concurrent.FutureTask.run(FutureTask.java:237)at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)at java.lang.Thread.run(Thread.java:841)LOGCAT=12-08 10:40:56.821 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:40:56.821 D/Dialog ( 9568): showing allowed12-08 10:40:56.921 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:40:58.721 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:01.671 D/AbsListView( 9568): Get MotionRecognitionManager12-08 10:41:03.181 D/AbsListView( 9568): onDetachedFromWindow12-08 10:41:03.231 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:04.651 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[LTE], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:04.651 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:04.651 D/Dialog ( 9568): showing allowed12-08 10:41:04.701 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[LTE], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:04.751 D/ProgressBar( 9568): updateDrawableBounds: left = 012-08 10:41:04.751 D/ProgressBar( 9568): updateDrawableBounds: top = 012-08 10:41:04.751 D/ProgressBar( 9568): updateDrawableBounds: right = 14412-08 10:41:04.751 D/ProgressBar( 9568): updateDrawableBounds: bottom = 14412-08 10:41:08.811 I/System.out( 9568): AsyncTask #4 calls detatch()12-08 10:41:08.871 D/ProgressBar( 9568): setProgressDrawable drawableHeight = 4812-08 10:41:08.891 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:08.891 D/Dialog ( 9568): showing allowed12-08 10:41:08.951 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:10.641 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:12.361 D/AbsListView( 9568): Get MotionRecognitionManager12-08 10:41:13.291 D/AbsListView( 9568): onDetachedFromWindow12-08 10:41:13.341 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:26.131 D/dalvikvm( 9568): GC_CONCURRENT freed 4410K, 24% free 20492K/26692K, paused 20ms+10ms, total 113ms12-08 10:41:26.131 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:26.141 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:26.141 D/Dialog ( 9568): showing allowed12-08 10:41:26.181 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:26.221 D/ProgressBar( 9568): updateDrawableBounds: left = 012-08 10:41:26.221 D/ProgressBar( 9568): updateDrawableBounds: top = 012-08 10:41:26.221 D/ProgressBar( 9568): updateDrawableBounds: right = 14412-08 10:41:26.221 D/ProgressBar( 9568): updateDrawableBounds: bottom = 14412-08 10:41:26.591 I/System.out( 9568): AsyncTask #5 calls detatch()12-08 10:41:26.631 D/ProgressBar( 9568): setProgressDrawable drawableHeight = 4812-08 10:41:26.641 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:26.641 D/Dialog ( 9568): showing allowed12-08 10:41:26.741 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:27.831 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:55.351 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:55.351 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:55.351 D/Dialog ( 9568): showing allowed12-08 10:41:55.381 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:41:55.421 D/ProgressBar( 9568): updateDrawableBounds: left = 012-08 10:41:55.421 D/ProgressBar( 9568): updateDrawableBounds: top = 012-08 10:41:55.421 D/ProgressBar( 9568): updateDrawableBounds: right = 14412-08 10:41:55.421 D/ProgressBar( 9568): updateDrawableBounds: bottom = 14412-08 10:41:55.801 I/System.out( 9568): AsyncTask #1 calls detatch()12-08 10:41:55.821 D/ProgressBar( 9568): setProgressDrawable drawableHeight = 4812-08 10:41:55.831 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:41:55.831 D/Dialog ( 9568): showing allowed12-08 10:41:55.911 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:41:57.031 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:42:45.371 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:42:45.381 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:42:45.381 D/Dialog ( 9568): showing allowed12-08 10:42:45.411 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:42:45.461 D/ProgressBar( 9568): updateDrawableBounds: left = 012-08 10:42:45.461 D/ProgressBar( 9568): updateDrawableBounds: top = 012-08 10:42:45.461 D/ProgressBar( 9568): updateDrawableBounds: right = 14412-08 10:42:45.461 D/ProgressBar( 9568): updateDrawableBounds: bottom = 14412-08 10:42:46.501 I/System.out( 9568): AsyncTask #2 calls detatch()12-08 10:42:46.531 D/ProgressBar( 9568): setProgressDrawable drawableHeight = 4812-08 10:42:46.551 D/dalvikvm( 9568): GC_CONCURRENT freed 3131K, 28% free 19338K/26692K, paused 3ms+5ms, total 57ms12-08 10:42:46.551 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:42:46.551 D/Dialog ( 9568): showing allowed12-08 10:42:46.681 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:42:48.011 D/ACRA ( 9568): Using custom Report Fields12-08 10:42:48.031 I/ACRA ( 9568): READ_LOGS granted! ACRA can include LogCat and DropBox data.12-08 10:42:48.101 D/ACRA ( 9568): Retrieving logcat output...12-08 10:42:48.131 D/ACRA ( 9568): Writing crash report file 1418053368000-IS_SILENT.stacktrace.12-08 10:42:48.131 D/ACRA ( 9568): About to start ReportSenderWorker from #handleException12-08 10:42:48.131 D/ACRA ( 9568): Mark all pending reports as approved.12-08 10:42:48.131 D/ACRA ( 9568): Looking for error files in /data/data/com.infragistics.shareplus/files12-08 10:42:48.131 D/ACRA ( 9568): #checkAndSendReports - start12-08 10:42:48.131 D/ACRA ( 9568): Looking for error files in /data/data/com.infragistics.shareplus/files12-08 10:42:48.131 I/ACRA ( 9568): Sending file 1418053368000-IS_SILENT.stacktrace12-08 10:42:48.141 D/ACRA ( 9568): ACRA sent Silent report.12-08 10:42:48.151 D/ACRA ( 9568): Waiting for Toast + worker...12-08 10:42:48.211 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:42:48.281 D/ACRA ( 9568): #checkAndSendReports - finish12-08 10:42:48.351 D/ACRA ( 9568): Wait for Toast + worker ended. Kill Application ? false12-08 10:42:54.001 W/IInputConnectionWrapper( 9568): showStatusIcon on inactive InputConnection12-08 10:43:04.521 D/Activity( 9568): #3 setTransGradationModeColor to false12-08 10:43:07.711 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:43:07.711 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:43:07.711 D/Dialog ( 9568): showing allowed12-08 10:43:07.751 D/ConnectivityManager( 9568): getActiveNetworkInfo : NetworkInfo: type: mobile[CDMA - eHRPD], state: CONNECTED/CONNECTED, reason: connected, extra: n.ispsn, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false12-08 10:43:07.781 D/ProgressBar( 9568): updateDrawableBounds: left = 012-08 10:43:07.781 D/ProgressBar( 9568): updateDrawableBounds: top = 012-08 10:43:07.781 D/ProgressBar( 9568): updateDrawableBounds: right = 14412-08 10:43:07.781 D/ProgressBar( 9568): updateDrawableBounds: bottom = 14412-08 10:43:08.211 I/System.out( 9568): AsyncTask #3 calls detatch()12-08 10:43:08.251 D/ProgressBar( 9568): setProgressDrawable drawableHeight = 4812-08 10:43:08.271 D/Dialog ( 9568): checkMirrorLinkEnabled returns : false12-08 10:43:08.271 D/Dialog ( 9568): showing allowed12-08 10:43:08.381 E/ViewRootImpl( 9568): sendUserActionEvent() mView == null12-08 10:43:09.121 D/ACRA ( 9568): Using custom Report Fields12-08 10:43:09.151 I/ACRA ( 9568): READ_LOGS granted! ACRA can include LogCat and DropBox data.12-08 10:43:09.231 D/ACRA ( 9568): Retrieving logcat output...__________________________Please describe the issue:
Hello Deepak,
I will be closing this support case since it is a duplicate from the previous case you created.
You can check my reply in the following link:
http://www.infragistics.com/community/forums/t/93712.aspx
Best regards
Gonzalo T Technical Support Engineer I Enterprise Mobility Infragistics, Inc.
