I have no problem to connect to out SharePoint site and I can see alle my documents. But it is showing up in a small tiny window in the middle of my screen wich are non resizable. Non of the commands work or buttons on the ribbon. Not able to configure the app.
Inside the small window I am able to navigate, but not to open any documents or execute any commands. The program seems quite useless. Several emails to support is not answered.
Hello Odd,
Thank you for posting at IG forums!
The issue you report sounds familiar. I assume you've selected Office365 as the authentication mode. Is your site an Office365 site?
Looking forward to hearing from you,
Thank's for your answer, here and on email. I don't use Office 365, but connected to my SharePoint site using "web authentication". Login in with "Windows Based authentication" solved my problem with the tiny window.
I am now trying out SharePlus and my first challenge is how to sync offline folders/documents and to browse documents and open them for edit. Some documents will open som will not. Only able to edit document properities.
Odd,
I'm glad the authentication issue has been solved.
Regarding offline support:
Once the list's offline settings are enabled and saved, the app will start synchorinizing the content after 30 seconds of inactivity or when you click the Refresh button.
There will be indicator badges over the icons of the offline-enabled lists that will help you tell which ones are completely synced (green). Once you go offline, the contents of these lists will be available for you to view them
Regarding editing documents. Do you have Office:Mac 2011? What document types are giving you a hard time?
