I am using filters in XamDataGrid. Some of them are using dropdown where the user can select a value. This is enabled by specifying:
FilterOperandUIType = FilterOperandUIType.Combo
How do I trigger filtering when the user selects the item from dropdown? So far I can only see options like OnCellValueChange (which is triggered whenever user presses a key OR selects item from dropdown) or OnEnterKey (which is triggered when user presses ENTER key on the dropdown). What I want is that filtering is only triggered when user selects an item from the dropdown, and not triggered in any other cases.
Is this possible?
Morris
Hello Morris,
