120
Chart Series not Visible on Initial View
I am using a XamDataChart in a Silverlight sdk tab control.  The chart has a Radial Area series and two Radial Line series.  The itemsource and visibility for these are bound to properties in a view model.  I also have a Legend on this tab for the chart.
Tab selection is controlled by the view model.  After the relevant properties are defined, the view model sets the tab to the one with this chart. At this point, one of the line series is not visible.    However, the legend shows all of the series, even the one that is not visible.
When I run the app, if I select another tab, then re-select the tab with the chart, the hidden series appears as it should.  I've tried many workarounds found on this and other forums to no avail.
Parents Reply Children
No Data
