hi
i using xamcomboeditor in project with dropdown and autocomplete is true.when i enter the first time it takes data save it and second time when i starts entering it shows highlight suggestions eg. is Acold is already entered. now i just need to enter Ac. After typing Ac it shows Acold{here bold chars treat as highlighted}.Now i press ESc to remove the highlight text and it shows "Ac" now i press Tab key to go to next Xcomboeditor but when i press tab the text is changed to Acold. i know it is appear because of autocomplete .
my purpose is when i press tab it should go to next textbox without changing the current entered text.
thanks
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
