Im trying to mask yy:ss, it seems not possibleI searched for a solution, i found Topic from 2012 of a guy who asked for the same thinghttp://www.infragistics.com/community/forums/t/68230.aspxIs it possible some how to do it? is there anywork around you suggest.
what Im trying to achieve is 00:00 - 99:50 , since hours,minutes, monthes, days limit is lower then 99 I thought about using the year fieldI would except any other suggion, I wanted to stay with DateTime() since xamDateTimeInput is working good with it.
Maybe it is possible to Bind double number with limit 00.00-99.59 and just change the "." (dot) to ":" so it will look like time field
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I used XamMaskedInput and set its ValueConstriant’s MaxInclusive Property to 99.59 in order to restrict the user from entering larger number. I also set the ValueToDispalyTextConverter in order to replace the “.” With “:”. Please let me know if this helps you or you have further questions on this matter.
Hi Stefan,
Thanks for the quick answer, I checked the file you sent meI may was not clear, I need the page to display 00:00 NOT 00.00is there any option to change the '.' to ':' in the UI? or you have another solution
thanks!
Hello Assaf,
I can suggest you change the Mask Property of the XamMaskedInput to "99:99". Please let me know if this helps you or you need further assistance on this matter.
did you try it? it is not working as i expected
I have modified the sample I sent you before with the suggested mask and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
thanks for the help
I used a diffrent controller to solve it.
Thanks again.
