Hi there,
I'm currently having an issue with a XamComboEditor that sometimes returns an unhandled exception.
This happens when the AutoComplete is used to get the data from the dropdown
It happens with no apparent reason and only occasionally.
This is the error that is happening (Silverlight application):
This is the Combo definition:
<ig:XamComboEditor x:Name="igOtherServiceTypes" Grid.Row="1" Grid.Column="1" Margin="10,10,10,10" Height="25" ItemsSource="{Binding OtherServiceTypes, Mode=TwoWay}" SelectedItem="{Binding Path=SelectedOtherServiceType, Mode=TwoWay}" IsEditable="True" AutoComplete="True" AutoCompleteDelay="500" AllowFiltering="True" DisplayMemberPath="OtherServicesTypeDescription" OpenDropDownOnTyping="True" TabIndex="0" cal:Message.Attach="Loaded = OtherServiceTypes_Loaded($source, $eventArgs)"> <i:Interaction.Behaviors> <sfb:ComboBoxSelectText/> </i:Interaction.Behaviors></ig:XamComboEditor>
Do you have any idea why this happens?
Thank you.
Hello Helder,
