How can I style the control, XamDateTimeEditor so that it will always shows mask whether the control is enabled & infocus or disabled, so users can see what data is expected in that control always.
For example if the masket is set to hh:mm, the control is enabled and in focus, it will display _ _ : _ _ I need this to visiable always. Can you tell us what properties to change in xaml?
thanks
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
