I have a XAMGrid bound to ObservableCollection<MyObject>. MyObject contains a number of fields including one field that is ObservableCollection<MyInterface>. MyInterface defines several properties, including a property Rows of type ObservableCollection<Object>. I have a few different classes that implement MyInterface, each implementing the Rows property with its own underlying object.
In XML, I have
<ig:XamGrid Name="myGrid" ItemsSource="{Binding Source={StaticResource MyObject}, Path=objects}"
<ig:TextColumn Key="objectAttr1" />
<ig:TextColumn Key="objectAttr2" />
<ig:ColumnLayout Key="MyInterfaceObservableCollection" >
<ig:ColumnLayout.Columns>
<ig:TextColumn Key=" interfaceProp1" />
<ig:TextColumn Key=" interfaceProp2" />
<ig:ColumnLayout AutoGenerateColumns="true" Key="Rows" >
</ig:ColumnLayout>
</ig:ColumnLayout.Columns>
<ig:XamGrid />
The grid displays and has the expected hierarchy of child bands. All objectAttr* columns and interfaceProp* columns display properly. When I expand the first Rows child band that implements MyInterface, it expands and displays the correct columns with the correct headers as defined in attributes of the underlying object. The problem I encounter is that when I expand the next Rows child band that implements a different underlying object, I see the columns from the first object and none of them are populated. If I refresh the page and open the Rows child bands in a different order, I always get the child band columns for the first Rows child band that I expand.
I would like to bind a XamGrid to an ObservableCollection<MyInterface> that returns differing rows and be able to see the appropriate columns for the different implementations of MyInterface. Is this possible?
