I found an example on http://quince.infragistics.com/Patterns/Tree-Table.aspx?lang=en#Solution
http://quince.infragistics.com/#/Main/ViewPattern$pattern=Tree-Table&lang=en/PatternExamples$guid=32e14521-eb07-4086-b66f-91998d8b159a
Silverlight
You can use the hierarchical data display capabilities of the NetAdvantage for Silverlight xamWebGrid control for this.
How can I use xamWebGrid to create a tree-table?
Thanks in advance.
The xamGrid doesn't support hierarchy specifically like the image you posted. It's more like this:
https://www.infragistics.com/samples/silverlight#/grid/hierarchical-data
With a bit of custom code you could make it look like this: https://www.infragistics.com/samples/silverlight#/grid/self-referencing-data
However, the expansion indicators won't be indented.
-SteveZ
