I am working on a prototype where user gets to edit/enter values within the grid. To meet with the requirement of having certain columns of xamgrid always is edit mode, we created template columns with datatemplate set to textboxes.
I could tab through these textboxes and enter values without any issues. The active cell is always in the grid view port until I group these columns. When ever I click inside first textbox (Symbol in the example) of the grouped column, the view port scrolls back to first column of the xamgrid. I don't have this issue when I click on rest of the columns (quantity and rate in example) in the group column.
Attached document shows screenshots and sample code to reproduce this issue.
Please let me know if I there is any fix / work around for this issue.
Experts from Infragistics team. Could you please help us with this issue?
There was a bug with GroupColumn that was causing the issue where it would scroll to the beginning
However that was fixed in one of the last couple SR's
-SteveZ
