Is there a way to change the background of a QuantitativeScale or other parts of a Bullet graph programmically.
I'm probably not approaching it correctly, but I was looking for something like:
xamBulletGraph1.Scale.QuantitativeScale.Background = "<color>";
I'm guessing I have to some type of Binding, like the other dynamic data - but do I have to create a "model" for this too? Or can I bind it straight to a variable?
Baby steps.... :-)
The Scale property returns the Quantitative Scale so you can change the background like this:
xamBulletGraph1.Scale.Background = new SolidColorBrush(Colors.Magenta);
The Background property is of type Brush and the snippet assigns a SolidColorBrush, which uses the predefined color Red - list with predefined colors.
You can also use Infragistics.ColorConverter.FromString("#FF2582A9") to obtain a color from a string:
xamBulletGraph1.Scale.Background = new SolidColorBrush(Infragistics.ColorConverter.FromString("#FF2582A9"));
Here are topics, which will guide you how to work with the Quantitative Scale and its Qualitative Ranges in code-behind - Quantitative Scale and Qualitative Ranges
Thanks!
