Hello,Why my CellStyle doesn't apply on this TemplateColumn ?
I've defined CellControl and ConditionalFormattingCellControl as an implicit style :
<Style TargetType="ig:CellControl"> ...
<Style TargetType="ig:ConditionalFormattingCellControl"> ...
Is there need to set a special style for IconConditionalFormatRule?
Clarification: I am a designer, I only use Blend and I don't code in C# ! Thanks
There is a limitation of ConditionalFormatting with implicit styles. You have to set the CellStyle property of the XamGrid to your custom style. The target type of the style should be ig:ConditionalFormattingCellControl.
As I was looking through your code I noticed that your custom style for ConditionalFormattingCellControl is missing some parts. You can get the default style of the ConditionalFormattingCellControl from the generic.xaml files that are provided when the product is installed:http://help.infragistics.com/Doc/Silverlight/2010.3/CLR4.0/?page=SL_DesignersGuide_Location_of_Generic_xaml_File.html
Hi,Thank for reply.I connected the CellStyle on ConditionalFormattingCellControl, it works but unfortunately the right part of lines takes default XamGrid style.This is to avoid this problem I use implicits styles.
I don't understand how to style this infinite column right ...Thank for your helpRegards
