Can I add a file to a zip file using the library InfragisticsSL4.Compression.v10.3?
yes you can. For further directions how to do it check out the online help for the Compression library and in particular Add an Entry to an Archive.
Hope this helps.
Can you please provide a sample application for inserting an image to an existing zip?
Got the answer...thank you very much...
