I'm attempting to style a bulletgraph similar to this:
I'm approaching this in my prototype by creating two Qualatative Ranges, and styling each appropriately.
<ig:QuantitativeScale.Ranges>
<ig:QualitativeRange Value="333" Background="Red" />
<ig:QualitativeRange Value="567" Background="Transparent" BorderBrush="Red"/>
</ig:QuantitativeScale.Ranges>
The problem I am encountering is that the BorderBrush and BorderThickness properties on QualatativeRange don't seem to have any effect - so my second range is always completely invisible. How might I implement a colored border?
For my second question, does xamBulletGraph support adding text to the datapoints, similar to the image above? This would need to be permanent, more than just a tooltip.
Thanks!
You can change the control template of the Range. Try using this code:
<Grid x:Name="LayoutRoot" Background="White">
<Grid.Resources>
<ControlTemplate x:Key="RangeTemplate">
<Border Background="{TemplateBinding Background}"
BorderThickness="{TemplateBinding BorderThickness}"
BorderBrush="{TemplateBinding BorderBrush}">
<TextBlock Text="{Binding Value, RelativeSource={RelativeSource TemplatedParent}}"
HorizontalAlignment="Right"
VerticalAlignment="Center"/>
</Border>
</ControlTemplate>
</Grid.Resources>
<ig:XamBulletGraph Height="100">
<ig:XamBulletGraph.Scale>
<ig:QuantitativeScale>
<ig:QualitativeRange Value="40"
Background="Red"
BorderBrush="Red"
BorderThickness="5"
Template="{StaticResource RangeTemplate}" />
<ig:QualitativeRange Value="90"
</ig:QuantitativeScale>
</ig:XamBulletGraph.Scale>
</ig:XamBulletGraph>
</Grid>
