I have used Xamgrid , where i hav hyperlink col for my projectid and i want to navigate to other webaddres
For Example: http://mytestsite/pages.aspx?projectid=1111
how can i provide this type of url on the click of my projectid hyperlinkcolumn , the projectid will differ for every cell , i am listing my projects which shows some data along with projectid , on click of particular projectid , the more details should be opened
Thanks in Advance
If you just want to create an additional column with a hyperlink based on another column you can use UnboundColumn and converter to create the hyperlink.
First you need a converter:
... public class Conv : IValueConverter { public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { if (value is int && targetType == typeof(Uri)) { return new Uri(string.Format("http://mytestsite/pages.aspx?projectid={0}", value)); } return null; } public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { throw new NotImplementedException(); } }
Then add an UnboundColumn:
... <UserControl.Resources> <local:Conv x:Key="Conv" /> </UserControl.Resources> ... <ig:XamGrid.Columns> <ig:TextColumn Key="Id" /> <ig:UnboundColumn Key="MyUnboundColumnWithHyperlink"> <ig:UnboundColumn.ItemTemplate> <DataTemplate> <HyperlinkButton Content="Navigate to Page" NavigateUri="{Binding RowData.Id, Converter={StaticResource Conv}}" /> </DataTemplate> </ig:UnboundColumn.ItemTemplate> </ig:UnboundColumn> </ig:XamGrid.Columns> ...
I hope that this will help you.
