I have created the WebCombo with AutoGenerateColumns=false and try to bind the datasource. I am unable to view the values in the webcombo , but when i tried to generate the webcombo with autogeneratecolumns=true then i got the columns
This is the expected behavior. When setting AutoGenerateColumns to False, you are supposed to create the columns yourself, typically in the InitializeLayout event.
AutoGenerateColumns Property
