Hello, i'm a report plus user and i have some issues that i don't know how to resolve:
1. I've tried de drill down functionallity and its only Works with datetime fields, its that right? or if its possible to do this with other fields can you explain me how, because i'm not find the way.
2. When i connect to analysis services report plus lost many function like the date fields drill down and calculated fields, i don't not if its my issue or its the way that it be. I've tried the datetime drill-down with Excel file and it's work but not wih analysis services.
3. Can reportplus manage link one dashboard with other tapping in some place in the first dashboard?
I thank you so much if you can help me.
Hello Gabriela,
Thank you for posting at IG Forums!
Please follow the below link that will help you with your question:
https://www.infragistics.com/community/blogs/b/gabriel-lopez/posts/reportplus-v2-1-available-for-download
Also, in order to drill down, the data must be aggregated.
Analysis Services Dimension has to have the “lesser level” data
Regarding the third question, unfortunately that's not possible right now.
Should you have further question please let me know.
Best regards,
Thank you Sebastian, i will try and i comment then if i could do that
Ok, perfect!
If you have any question please let me know.
I'll be looking forward to hearing from you,
Good morning Sebastian,
I have a question, I've tried the drill-down function, I create my jerarquies and it's work fine, but i realize that it don't work with all charts types, specifically with pie chart. Can you confirm it or tell me if i do something wrong again.
thank you
