I would like to provide a checkbox in a column header (in order to provide a 'select all' capability). It seems I can provide a checkbox control in a template column for the cell itself but is there a way to customize the header?
Hello Charles,
Thank you for the post. You can customize the header by using IgrTemplateHeader. i did some research and find this attached sample can give you some direction to put another control in the grid header using template header.
demo.zip
