Hi All,
We are using ignite controls - 20132.2364 and it is crashing with the latest chrome version.
Error details are as below: Uncaught TypeError: n.igDialog is not a function .
Can someone help with the resolution for the same.
Thank you for posting in Infragistics Forums! We will need more information in order to help you. What controls do you have in the page? Did it start throwing the error after the you upgraded Chrome? Does it throw the error on other browsers? Also keep in mind that 13.2 in not supported version anymore. If it is an issue in the new version of Chrome an upgrade might be the only solution.
I hope this helps!
Kind regards, Petko Zhekov Software Developer
Thank you for the quick response. We are using many infragistics controls on the screen which includes -infragistics menu (which is loading). Apart from the infragistics menu - we are using infragistics tabs, dialogs, calendar, grid, listbox on the UI. We are getting a blank screen apart from the menu. It is failing with the Chrome version 59.0.3071.115. If we roll back to a base installer of chrome it does work.
Would appreciate if you have any leads on this issue apart from upgrading the infragistics version.
Anitha
I tested the build with the latest version of Chrome but I didn’t see any issues. I’m sending you a sample. Please modify it with your setup in order to reproduce the issue and send it back to me.
I’m looking forward to your response!
