Is it possible to bind data from different levels?
Here is a trimmed down example JSON: https://pastebin.com/hPwK9hnh
In the example here I should get 2 series one for ID 574 and one for ID 573.
Each of these series will have a list of data point positions.
On the Y axis there should be the 'B' (balance) values for each data point.
On the X axis there should be the Dates for each data point.
Is this possible to do?
Kind regards Matthias
Hello Mathias,
If you are talking about different levels of hierarchry in the data you would use the responseDataKey on the main chat or series depending on how you are assigning data:
https://www.igniteui.com/help/api/2016.2/ui.igDataChart#options:responseDataKey
https://www.igniteui.com/help/api/2016.2/ui.igDataChart#options:series.responseDataKey
If you want to specify what member is used for which axis of a series you can set the x/yMemberPath:https://www.igniteui.com/help/api/2016.2/ui.igDataChart#options:series.xMemberPath
https://www.igniteui.com/help/api/2016.2/ui.igDataChart#options:series.yMemberPath
Thanks it helped me
