I have a grid with a paginator (paging mode: remote) and filterable columns. When I navigate to any page and then attempt to filter its results, the paginator goes back to the first page, quite to my dismay.
As I can see in the code this is done like this by design and there seems to be no way it can be avoided.
My IgniteUI-Angular version is 14.0.7.
I would like to understand what's the reasoning/motivation behind this design decision.
Hi César,
Thank you for posting to Infragistics Community!
I have been looking into your question and what I can say is that this is the behavior not only with remote paging, but with paging and filtering in general. You are correct that this is by design. An argument in favor of this behavior is that the user would most probably like to see the filtered in results form the start. Furthermore, let’s say that the user is on page 5 when applying a filter. The result set has fewer results, so the filtered data now spans 3 pages only. If the paginator was to remain on page 5, which would not exist at this point, an erroneous behavior would be introduced.
Having this in mind, it is possible to achieve your requirement with some custom application level code both for the paging within the grid, as well as remote. Here is a StackBlitz sample for the first case. The solution involves handling the filtering and filteringDone events of the grid. In the first one, the current page of the paginator could be stored in a variable and in the second, the page could be navigated to after filtering. There is the logic about navigating to the last available page, in case there were more pages than the saved current page before filtering.
public filtering(event: IFilteringEventArgs) { this.pageBeforeFiltering = this.paginator.page; } public filteringDone(event: IFilteringExpressionsTree) { if (this.pageBeforeFiltering <= this.paginator.totalPages) { this.paginator.page = this.pageBeforeFiltering; } else { this.paginator.page = this.paginator.totalPages; } }
Regarding remote paging with filtering, as you are probably already familiar, most of this functionality is implemented on application level by leveraging the grid API. The Grid Remote Data Operations topic provides sample code and demos on how to get it up and running. Developers could further customize the code in order to implement more specific requirements.
For your convenience, I have prepared this other sample with remote paging and filtering which also follows the above approach to keep the page on filtering. Please, feel free to modify it according to your proper configuration.
Please, check the samples out and let me know if they properly address your question.
Best regards, Bozhidara Pachilova Associate Software Developer
Hi Bozhidata,
thanks a lot for your fast and detailed answer. I still have to discuss the subject with my PO but, as far as I can tell, the filtering requirements are just "fast filter the results in a given column by matching the string typed by the user, *just in the current page*". In other words: local filtering in the current page, not filtering the whole result set that feeds the paginated grid.
Your approach (remembering the page the user was in, then navigating to it or just restoring) might work, but it seems too complex for something as simple as filtering the results in the current page. I think I will use the igxFilterCellTemplate to trick the grid into putting an input field at the header, then just let the input manually control the data that is fed into the grid (i.e., without using the grid's filtering capabilities).
Best regards
Thank you for following up!
The built-in grid filtering works for the entire grid data, which is also typical for most of the grid solutions out there. Additionally, our remote data examples also function on this basis.
Based on my experience, I haven’t yet encountered such a use case yet, nevertheless, I suppose it could be implemented on application level. I believe the IgxGrid exposes a flexible API for different scenarios like this. Also, it might be question of simple data filtering and displaying the result set in the grid, as you mentioned.
If you require any further assistance on the matter, please let me know.
