We are using ignite ui version 11.1.32 and using hierarchical grid to show the data, We need to Export the data to excel on click of export button. On Export only the Excel file is getting downloaded without any data. Please find below the code used. Could you please help to sought this out.
HTML:
Hello Bavisha,
Thank you for posting to Infragistics Community!
I have been looking into the provided code snippets and after an investigation, I was able to determine that although the described behavior is reproducible it is also expected.
As mentioned in our official release notes here, support for exporting data from IgxHierarchicalGrid is introduced in version 12.0.0 and due to this only the excel file is being downloaded without any data.
Having this in mind, what I could suggest is either updating your application to use a higher version of Ignite UI for Angular, which supports this functionality, or using a different component for representing your data, e.g. IgxTreeGridComponent. This component is also used to display and manipulate hierarchical data and its functionality for exporting data to Excel is supported in Ignite UI for Angular version 11.1.32.
In addition, our official documents offer an update guide, which has a detailed explanation of the steps needed to update Ignite UI for Angular successfully, as well as information about changes that need to be applied manually.
Please let me know if you need any further assistance.
Sincerely,Riva IvanovaEntry Level Software Developer
Hi Riva,
How can we find particular component will not be supported in particular version without reaching to support team.
Thanks in advance.
Thank you for following up!
I have been looking into your question and what I could say is that our official documentation is a great source of information to refer to for supported functionalities and/or changes regarding any of our components. Moreover, it provides the option to select for which of the latest versions of Ignite UI for Angular to receive detailed information. Here could be found the documentation for version 11.1.x.
Furthermore, if a particular piece of information could not be found in the documentation, another resource, which was mentioned in the previous response, are our official release notes. With every release comes a set of release notes that reflects the state of resolved issues and new additions from the previous release. The full release notes for each version of Ignite UI for Angular are located on our GitHub repository.
Additionally, another possible source of information, which I believe you will find very helpful, is the source code for the specific version. The source code for Ignite UI for Angular version 11.1.x could be found here.
Thank you.
I am glad that you find my suggestions helpful.
Thank you for using Infragistics components!
Regards,Riva IvanovaEntry Level Software Developer
