I have a currency column that can have multiple currencies. Is there a method by which in excel style filtering menu not appear the currency but only the numerical value? Now, for example, if I have values in USD and EUR all the values have associated the USD currency which is not exactly correct.
Anca
Hello Anca,
I have been looking at your question and I have prepared a small sample trying to reproduce the described behavior. An approach I could suggest in order only numeric values to appear in the Excel Style Filtering menu is to set the column dataType to number and use ng-template with CurrencyPipe to display the currencies like the following:
<ng-template igxCell let-cell="cell"> {{ cell.value | currency}} </ng-template>
However, having in mind that the column can have multiple currencies, I could suggest using CurrencyPipe's currencyCode parameter to set the appropriate code.
Here could be found my sample for your reference where I am using a custom method to receive the currency code for each value. Please test it on your side and let me know if you need any further assistance.
If this is not an accurate demonstration of what you are trying to achieve, please feel free to modify it and send it back to me along with steps to reproduce.
Having a sample, which I can debug on my side, will be highly appreciated and extremely helpful for providing you with a solution as soon as possible.
Sincerely,Riva IvanovaEntry Level Software Developer
Thank you for your answer.
Your solution worked!
Sincerely,
Anca Theodora
I am glad that you find my suggestion helpful.Thank you for using Infragistics components.
Regards,Riva IvanovaEntry Level Software Developer
