I found a issue with Angular Donut chart legend and label does not work for lower data values. for example I have the below dataset and link to sample https://stackblitz.com/edit/github-npqlpu?file=src%2Fapp%2Fdoughnut-chart-legend%2Fdoughnut-chart-legend.component.ts
Hello Kalesha,
By default in the IgxDoughnutChart, there is an "others slice" that is determined based on the data that is bound to the chart and it will summarize all small outliers into a single slice. This others slice can be turned off by setting the "othersCategoryThreshold" property on the igx-ring-series to 0. This will prevent the others slice from showing, and then all of your data items will appear in the chart.
