Hello!
i'm developing a igx-grid with summaries. The summaries dosn' appear unitl i select "inspect item" in chrome.
Any ideas??
Thank you very much.
My code:
The problem:
When i click "inspect element" in chrome, its works
any ideas???
Sorry, my code is
I have created a sample trying to reproduce the described behavior based on the provided screenshots. On my side everything works as excepted, the summaries are rendered correctly.
Attached you will find my sample. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce.
2148.Sample.zip
Hello Martin, how are u?
We have the same solutions, but my solution doesn' work fine.
My ts
import { Component, OnInit, ViewChild, ViewEncapsulation } from "@angular/core"; import { OrderService } from './orders.service'; import { IgxGridComponent, IgxNumberSummaryOperand, IgxSummaryResult, IgxExcelExporterOptions, IgxExcelExporterService } from "igniteui-angular"; @Component({ encapsulation: ViewEncapsulation.None, selector: "app-orders", templateUrl: "./orders.component.html", styleUrls: ["./orders.component.scss"] }) export class OrderComponent implements OnInit { @ViewChild("grid1", { read: IgxGridComponent }) public grid1: IgxGridComponent; public discontinuedSummary = DiscontinuedSummary; public data; public OrderId = 0; constructor(private service: OrderService, private excelExport: IgxExcelExporterService) { } ngOnInit() { this.GetOrders(); } public GetOrders(){ this.service.GetOrders().then(res =>{ let out = <any>res; if(out){ console.log(out.Result); this.data = out.Result; } else{ this.data = []; } }) } public exportButtonHandler() { this.excelExport.export(this.grid1, new IgxExcelExporterOptions("ExportFileFromOrders")); } } class DiscontinuedSummary extends IgxNumberSummaryOperand { constructor() { super(); } public operate(data?: any[]): IgxSummaryResult[] { const result = []; result.push({ key: "ordenes", label: "Cantidad órdenes", summaryResult: data.length }); result.push({ key: "total", label: "Total", summaryResult: IgxNumberSummaryOperand.sum(data) }); result.push({ key: "maximo", label: "Max", summaryResult: IgxNumberSummaryOperand.max(data) }); return result; } }
My html
<div class="grid_wrapper"> <igx-grid igxPreventDocumentScroll #grid1 [data]="data" [autoGenerate]="false" height="800px" width="100%" [paging]="true" [perPage]="25" [allowFiltering]="true"> <igx-column field="OrderId" header="Order ID" sortable="true"> </igx-column> <igx-column field="OriginalPalletBarcode" header="Pallet Barcode" > </igx-column> <igx-column field="Barcodes" header="Cods Barra"> </igx-column> <igx-column field="Destination" header="Destino" sortable="true"> </igx-column> <igx-column field="Type" header="Mundo" sortable="true"> </igx-column> <igx-column field="SKU" header="SKU"> </igx-column> <igx-column field="Description" header="Descripcion"> </igx-column> <igx-column field="InitialQuantity" header="Cantidad inicial" dataType="number" editable="true" [hasSummary]="true" [summaries]="discontinuedSummary"> </igx-column> <igx-column field="FallabelaCreationDate" header="Creación orden" sortable="true"> </igx-column> </igx-grid> <button class="btn" igxButton="raised" igxButtonColor="white" igxButtonBackground="#731963" igxRipple (click)="exportButtonHandler()">Export Data</button> </div>
any ideas?
Hello Pedro,
I am fine, thank you. I hope you are too.
Thank you for the code snippets, however, without a runnable sample I cannot debug it and therefore it will be hard for me to know what exactly is the issue. Please modify the sample I have sent you that reproduces the behavior you are experiencing.
