I have a simple ultrawebgrid defined like so...
<igtbl:UltraWebGrid ID="uwgDistricts" runat="server" Width="100%"> <DisplayLayout ViewType="Flat" > <FrameStyle Height="470px"/> </DisplayLayout></igtbl:UltraWebGrid>
with an editable column defined like so...
With .FromKey("sName") .Width = New Unit("15%") .FieldLen = 50 .DefaultValue = "" .AllowNull = False .Header.Title = "The name of the District."End With
and the table like so...
With uwgDistricts.DisplayLayout .CellClickActionDefault = CellClickAction.Edit .SelectTypeRowDefault = SelectType.Single .AllowUpdateDefault = AllowUpdate.Yes .AllowDeleteDefault = AllowDelete.Yes .AllowAddNewDefault = AllowDelete.Yes .CellPaddingDefault = 1 .CellSpacingDefault = 1 .Pager.AllowPaging = False .TableLayout = TableLayout.Fixed .StationaryMargins = StationaryMargins.Header .AllowSortingDefault = AllowSorting.OnClient .HeaderClickActionDefault = HeaderClickAction.SortSingle .HeaderStyleDefault.BackColor = Drawing.Color.FromArgb(&H2B64A7)End With
There's a skin defined that contains the line...
<EditCellStyleDefault cssClass="GridEditCellStyleDefault"/>
and the class is defined like so...
.GridEditCellStyleDefault { background-color:white; color:Black; font: normal 8pt arial; vertical-align:middle; border:0pt none black; padding:0px;}
When I render this in IE7 or IE8 compatability mode and click in the field to edit it the edit area fills the cell correctly. But in IE8 non-compatability mode the edit area is not wide or high enough and the original contents of the cell peep around the edge. I know the GridEditCellStyleDefault class is being used because I can change the background-color of the edit area. I've tried specifying padding, height, min-height and none of them fix the problem. I'm using 2009v2.
bump - surely I'm not the only person with this problem?
Look at this
https://www.infragistics.com/community/forums/f/retired-products-and-controls/36753/ultrawebgrid-error-document-getboxobjectfor-is-not-a-function
