15
Setup for Xamarin forms
Hello Infragistics team,
   I looking for free trail for 30 day's for xamarin project. I tried to setup for xamarin forms.
  1. I downloaded Infragistics_Ultimate_20191_WithSamplesAndHelp.zip file then run this  Infragistics_DevTools_20191.exe and setupsuccessfully done.
  2. Then I downloaded xamarin_lesson_code.zip and extract it. Open Starter Project in visual studio 2019 but i am facing some problem for related infragistics packages   and i have available package source.
Parents
No Data
Reply
  • 34430
    Hello Deepak,
    I have been investigating into the behavior you are seeing, and this simply sounds like the NuGet packages are not available at your C:\Users\Public\Documents\Infragistics\NuGet source. I would be curious as to what exists at that directory on your machine.
    That said, if you have installed the latest Trial of Infragistics for Xamarin.Forms, I would expect that you should have an Infragistics_Xamarin_NuGet_Trial folder at the following directory, assuming you installed to the default location:
    C:\Program Files (x86)\Infragistics\2019.1\Xamarin\NuGet
    Note, you will need to extract the .zip file there, and once you do, you should be able to point a NuGet feed to it and then use the packages. Please try this on your end and let me know of the results.
Children
No Data
