I hve a question in XamLine Chart. I am using Date in Label for X-Axis and set Autorange to false. I specified the Minimum,Maximum and Unit for the range and the chart shows correctly. What I need is I want to remove weekend Labels from the X-Axis. Is it possible and how I can do so? Please reply.
Thanks & Regards,
Mukesh
Hello Mukesh,
Looks like you have asked the same in the following forum post and it has been answered.
http://community.infragistics.com/forums/p/54656/289108.aspx#
Max Rivlin"] There is currently no way to selectively hide axis labels. If your labels are a part of the data source, then you would have to either set the weekend labels to an empty string, or create an adapter that filters out weekends from your data.
