We have purchased Infragistics WPF Controls and I'm not able to create series dynamically using MVVM.
Is there a way to do it withour code-behind ? I want to use the same axis for my collection od Column Series add a legend and ToolTips. Please provide for me an MVVM-Friendly solution !Thanks !
Hello Nassim,
Thank you for your post.
To achieve your requirement, I would recommend that you take a look at the following forum thread: http://www.infragistics.com/community/forums/t/40011.aspx?PageIndex=1.
I realize that some of the posts on that forum thread reference the XamChart, which is a much older control, but further down the thread you will notice some posts from user [Infragistics] Graham Murray regarding a SeriesBinder behavior. This behavior allows dynamic creation of XamDataChart series in an MVVM way.
As much of the code on that forum thread is somewhat difficult to read, I have created a sample project using the SeriesBinder to create ColumnSeries dynamically with a legend and tooltips. This sample project is attached to this post. I hope it helps you.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
What a great answer with great example ! Thank you Andrew.
Sincerly,
Nassim
I'm having this issue as well.. I would like to dynamically add ColumnSeries via MVVM to my XamDataChart, but I'm unable to see the attached solution on the thread. Can this be attached? I would really appreciate it.
Thank you.
Cristina.
Hello Christina,
I am unsure why exactly the sample project that was attached to my original post was lost, but I am reattaching it here.
XamDataChartColumnSeriesBinderCase.zip
