Can we achieve this look and feel with the infragistics tree? ( Tree shown on the picture is a TreeView from Windows ). ( With the fullrow select and rootlines, selection color etc. )
Many Thanks.
this.ultraTree1.DisplayStyle = Infragistics.Win.UltraWinTree.UltraTreeDisplayStyle.WindowsVista;
This setting is turned on, bu i don't get the full row select ( with the expansion nodes ) and the selected node color. Can this be caused by override settings? Do we must set this to default values ?
Thanks.
I am not sure what you mean by "the selected node color.", but to get full row select, try this:
this.ultraTree1.DisplayStyle = Infragistics.Win.UltraWinTree.UltraTreeDisplayStyle.WindowsVista; this.ultraTree1.FullRowSelect = true; this.ultraTree1.ShowRootLines = false; this.ultraTree1.ShowLines = false;
Thanks, that worked for me! But its not possible to show expansion indicators with full row select? Because i dont see the expansion indicators.
That is correct. You cannot show expansion indicators on the root level when using FullRowSelect. This is consistent with how the inbox tree control works.
