How can I change the size of the triangular arrows in WinCarousel scroll buttons?Same issue pertaining to the drop down arrow in Drop Down Button.
Thank you.
Hello Tyler,
These arrows are actually a build in images for both Carousel and DropDownButton. One easy way to set your own custom images is by creating your custom style library via AppStylist. More about this application you may find by following the next link http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Styling_Guide_Styling_Your_Application.html.
You can also set these images by implementing IUIElementDrawFilter interface. Please check the following link where you may find additional information about this interface http://help.infragistics.com/Help/Doc/WinForms/2015.2/CLR4.0/html/Embedding_WinChart_Inside_WinGrid_Cells_Using_A_DrawFilter.html.
Please let me know if you need any additional information.
Thank you for using Infragistics Controls.
