I find pie charts crashing when the count of the mutable array assigned to the pie charts is large. I have tried to verify this by increasing the size of the mutable array in igPieChartViewController.m, I have observed the following behavior:
Please help me resolve this issue. In my app I need to create pie charts with slice count as mush as 50.
Hi Laxman,
I created a stress test project this morning that creates 1000 slices and it didn't experience any issues or crashes. I've attached the project to this post for you to take a look at. You'll need to remove the IGChart.framework reference and add your copy of it.
When it comes to the project you have that experienced the issue, pay attention to the error you're seeing in Xcode after the crash. It may provide some insight into some portion of your code that may need a quick fix, or possibly you're forgetting to retain the data array or data source helper.
Hi Torrey,
Thank you for you help. The following line solved my problem for me, I guess I had missed it earlier.
pieChartView.othersCategoryThreshold = 0;
