I am using the WebImageViewer for the first time and I have having an issue with displaying the complete width of an image. There seems to be some left and right padding within the viewer preventing the full width of the image from displaying, but can't see the reason for it. I've set the control as shown below and images themselves are 1024x768.
<ig:WebImageViewer ID="WebImageViewer" runat="server" BorderStyle="Ridge" BorderWidth="5" Width="1050px" hieight="800" > </ig:WebImageViewer>
code behind:
protected void Page_Load(object sender, EventArgs e) { if (this.IsPostBack) return; // Get a list of images var serverPath = HttpContext.Current.Server.MapPath("~/Uploads/"); string[] imgs = System.IO.Directory.GetFiles(serverPath); // Add a new ImageItem to the WebImageViewer per image foreach (string img in imgs) { string theFile = "~/Uploads/" + System.IO.Path.GetFileName(img); this.WebImageViewer.Items.Add( new Infragistics.Web.UI.ListControls.ImageItem(theFile, "test", "test")); } }
Below is what I'm seeing in the browser:
The height seems fine, but the complete width of the image is not being displayed within the control. Please let me know what the issue might be.
Barinder
Hello,Thank you for contacting us.
Could you please try to attached the image again, because it seems that our system somehow rejected it.
In order to change how the viewer to show the pictures, you can change the width and height of the control.
Simple image:
