I have a very simple situation.
I have a webdatagrid on the page. I have a BindingList full of custom objects. At runtime I set the datasource of the webdatagrid to the BindingList, and then I call DataBind().
When the page renders, there is nothing there, except when I look at View Source, I see all the items. They just don't show in the browser. What is going on?
Also, I don't know if it matters, but when I look at the View Source, I see a couple tables with style set to "visibility:hidden".
Found the problem. I had started the project as a plain vanilla ASP.NET web app (instead of an AJAX-enabled ASP.NET web app), so the web.config file was not set to load the right scripts etc.
Once I copied a web.config file from an "AJAX-enabled ASP.NET web app", all worked as expected.
I have the same problem, but I'm using framework 4.0, so ajax is already enabled on the asp.net web application template.
I have a page with the WebDataGrid on it, and everything is fine when I run it from VS, but when I deploy it, the WebDataGrid does not load into the html code, any idea what I may be missing, do I need something extra on my machine.config or web.config?
NOTE: I've logged on the server side the number of rows in my WebDataGrid and everything seems right, and I'm using firefox with firebug to debug the client side and no error of javascript or whatsoever is thrown.
(and my columns are not hidden)
I've opened another thread for my problem (don't know whats the protocol when a post has a verified answer, sorry).
www.infragistics.com/.../383269.aspx
