225
X Axis scale with no corresponding data item
In the examples provided in SamplesBrowser project, the same data is being assigned to both xAxis and series. So, for each dataItem in series, there is a corresponding label in xAxis.
(in your example a value is randomly generated for each month)
public CategoryDataSample() {
double curr = 100;
double curr2 = 300;
String[] months = new String[] { "Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec" };
for (int i = 0; i < 12; i++) {
curr += Math.random() * 4 - 2;
curr2 += Math.random() * 4 - 2;
CategoryDataItem newItem = new CategoryDataItem();
newItem.label = months[i];
newItem.setValue(Math.min(curr, curr2));
newItem.highValue = Math.max(curr, curr2);
add(newItem);
testData = new CategoryDataSample();
testData2 = new CategoryDataSample();
xAxis.setDataSource(testData);
series2.setDataSource(testData2);
Is it possible to have a graph with a 12 month xAxis scale but dataitem for only a couple of the months.
e.g. "Jan": 25, "Mar": 60, "Jul": 42, "Nov": 50
Parents
No Data
Reply
  • 14517
    Verified Answer
    Hello Elton,
    You can add points to your underlying data source with a value of Double.NaN in order to create “blank” spaces in the chart which will result in the Labels being added without any data points. For example:
    public TestData() {
           double curr = 10.0;
           double curr2 = 20.0;
                  curr += Math.random() * 4.0 - 2.0;
                  curr2 += Math.random() * 4.0 - 2.0;
                  TestDataItem newItem = new TestDataItem();
                  newItem.setLabel(months[i]);
                  if (i>6 && i < 9)
                         newItem.setValue(Double.NaN);
                         add(newItem);
                  else
                  add(newItem);
    By default the series will stop at the last point value and then continue again when a new value is discovered.
    As a side note, if you were missing points in your data but wanted the series to continue over those points, you could set the UnknownValuePlotting property on the series to LinearInterpolate:
               lineSeries.setUnknownValuePlotting(UnknownValuePlotting.LINEARINTERPOLATE);
    Sincerely,
    Valerie
    Developer Support Supervisor - XAML
    www.infragistics.com/support
Children
No Data
