We are testing the use of SharePlus for iOS in combination with QuickOffice Pro.
We encountered the following issue;
We opened a Word 2010 document as an attachment to a SharePoint list (2010 SP1) and edited it through QuickOffice Pro.
After that we used the 'Save back' option from Quick Office Pro to send the document back to SharePlus. Here we get the question to update the item.
Everything seems to go allright. However we notice the following.
A second attachment has appeared under the list item with the name "13_.000". The original file is also there, but hasn't been updated. The file "13_.000" can't be opened because it lacks the correct file extension.
When downloading it (Through IE 8) it is saved as a ZIP file. Rename the extension back to docx allowes it to be opened again in Word 2010. The changes are now visible.
Is this a known issue?
Hi Amphia,
Thank you for posting at IG forums!
We hadn't came accross this issue before. I have reported it to the developers and it is being reviewed now.
I will update this post as soon as I have news for you.
Thanks!
Hi Javier,
Any news on a possible solution for the reported issue?
Michel
Amphia,
Thank you for your patience!
A fix for this issue was implemented in v3.2 which will be out in the App Store next week, or as soon as Apple approves it.
Best regards,
Thank you for solving this. We'll be downloading as soon as it comes available.
Just tested the new version. Probleem is indeed solved. Thx.
I’m glad SharePlus is working as expected now.We are always working in improving the application we deliver to our customers. The best way you can help us is by submitting a review of SharePlus in Apple’s App Store: it spreads your voice to hundreds of thousands of people and allows us to know exactly what our customers need.I’d appreciate a lot if you visited the App Store and submitted a review of SharePlus.Thanks in advance,
