I'm using your Excel Export framework to export data to Excel. I set a custom format string to a cell but it seems that the Excel Export library does something to the string when applying it to the Excel. This leads to a situation where the format string is not correct in Excel. I am using Finnish settings for separators.
The format string that I set in code is ### ### ### ### ### ##0,0000
When I look at the Excel formatting, I can see that the custom format string is ###\ ###\ ###\ ###\ ###\ ##0
So something is adding the backslashes to the format string. If I remove the backslashes in Excel, I get the correct formatting.
I'm using Infragistics 14.1.20141.2138
Is there something I can do to prevent the backslashes being added?
Hello Antti,
I have logged this with development under ID: 187263 and I have also created a support ticket on your behalf:CAS-149906-R3L3Z5 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://www.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://www.infragistics.com/Membership/MySupport.aspx
Thanks!
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
https://www.infragistics.com/my-account/keys-and-downloads/
