Hello, I'm trying to determine if the XamMenu control can be used the way I need. I am trying to simulate a "pinned items" feature
I need a menu with checkable items.Items can be checked or unchecked without actually selecting the menuitem or closing the menuWhen items are selected the isChecked property is not effected.The isChecked only gets changed when clicking the checkbox directly.
As far as I can tell right now, when you click an item the checked/unchecked and clicked events both get called, no mattter if you click the checkbox or the menuitem itself.
Can I achieve this with this control, or will i need to make a datatemplate and add my own checkbox?
Your best option is to use your own Data Template with a checkbox control.
Valerie
Do you have any other questions on this matter?
not right now, thanks
