Hi~
I use UltraWebTab. I want to know if I can add tabs in Javascript. Tab calls ContentPane.TargetUrl = "aspx page". When I click button, I knew it occured postback. So all tabs in contentPane reload. and I couln't find any solution, property, some articles about ultrawebtab.
Do you know any solution about this? Client side or Server side.
If you help me, I would really appreiciate.
Tahank you.
Please take a look at the following forum post which addresses similar questions:
https://www.infragistics.com/community/forums/f/retired-products-and-controls/31088/how-to-add-a-tab-from-javascript/171235#171235
Hi, Radoslav.
Thank you for replying my question. I saw the answer that you replied. Does that mean using WebAsyncRefreshPanel in each Tabs or tab in WebAsyncRefreshPanel?? Actually I understood that article.
Let me explain my problem again. I can explain some example with a samples of infragistics. Frist, you can open url http://samples.infragistics.com/2009.2/WebFeatureBrowser/Default.aspx go to ASP.NET(AJAX Enabled)-> WebTab-Multi -> Page Tab.Then you can add tab with 'Add Tab with...' button. .When tab of 'Infragistic' named is added, click any menu in content, .and then Click 'Add Tab with..' Button. .you can see that 'infragistics' tab is reloaded. .I quess that when I click button, it occur postback. so contents of all tabs are reloaded. is that right?
I'm working on a project with using webtab. Are they all reloaded, It's meanless to use WebTab. I'm look for the solution for about a week but I couldn't find it. If your answer is same as my question. can you explain more?? or Do you have any ideas about my problem??
Please reply my question... Thank you.
Hello YuSeon,
eveAn said:I quess that when I click button, it occur postback. so contents of all tabs are reloaded. is that right?
In the current implementation of the sample the answer is yes all tabs are reloaded. You can use WebTab control to load tab content on demand: how to do that you can see the following documentation:
Overview of Asynchronous Postbacks in WebTab also this docs in this way can be optimized the performance.
