Whenever I add a appointment to the Xammonthview from my viewmodel that's not within the displayed datarange, the control doesn't scroll down to that appointment. For instance, if I set a appointment 4 months out from the current month in my viewmodel, I would like to see that appointment. I noticed that the control doesn't have a visible dates property, so how would I go about this?
Hello Theo,
Thank you for your post.
The XamMonthView control has a BringIntoView() method that accepts a DateTime as a parameter. When called, the control will scroll that particular date into view. If you call this method with the end date of your appointment when you add that particular appointment, you can scroll your appointment into view as it is added. Note, that if you want to scroll the entire month that particular appointment belongs to into view, you will need to scroll the last day of that month into view.
I have attached a sample project to demonstrate the above. I hope this helps you.
Sincerely,AndrewAssociate Developer
