I need to use some reports which created from SSRS (Reporting Services) that have many report parameters.
Thanks & Best Regards,
O.Adithep
Sorry, I mean pages data set to use with SSRS parameters.
do you want to use binding to bind the selected value in pages to the value of an SSRS parameter in a given report? you can achieve this by selecting "Parameter" instead of "Field" when defining the binding for the widget containing the SSRS report.
or do you want to load a pages data set with the valid values of an SSRS parameter?
