215
Script for upload template column in grid, stops grid from filtering/paging
I am using ASP.NET MVC4 and 2013 vol1 with VS 2012.
Martin from Infragistics was kind enough to give me a solution on how to add an upload control to a grid column.
https://www.infragistics.com/community/forums/f/ignite-ui-for-javascript/80549/adding-an-upload-control-into-a-grid-template-column
ISSUE #1
I managed to get the upload working, yet one thing I discovered was that the script required by the uploader actually prevents the grid from doing any paging or filtering. Even though the script for uploading works. No client-side error is thrown in IE and I can't seem to figure out the problem.
I have marked the script in the code that is the problem.
ISSUE #2
After making an edit to a row, the fileupload template column disappears.
I'm not sure if this issue is related, but how do I prevent the fileupload template column from going away?
Here is a link to the solution with the grid problem.
http://www.meltdown.co.za/upload/upload.zip
Parents Reply Children
No Data
