i am working on a ASP.NET MVC Single Page Application and i am using jQuery iggrid control. So i have noticed that if i use the following approach to create the grid:
$.ig.loader('igGrid.*', function () {
if ($('selector').data("igGrid") === undefined) {
$('grid selector').igGrid(gridOptions);
the css <link> elements are appended at the bottom of the <head> tag, so everything works fine so far. But if i delete and then create again a new grid without refreshing the page(as i said previously this is a Single Page Application), then these css <link> elements are appended again in the <head> and each time when i create a new grid this happens again. So i looked in the infragistics.loader.js file and i noticed that in this function:
isLoadedCss: function (a) { return (a && a.length > 0 ? this._isLoadedHeadElem(a.substring(a.lastIndexOf("/")), "link") : false) },
the second parameter of this._isLoadedHeadElem, "link" should be uppercase, when i change this, the condition in this function:
_isLoadedHeadElem: function (f, g) { var b = document.documentElement, c, d = b.childNodes.length, a, e; if (b.nodeName !== "HEAD") { for (c = 0; c < d; c++) { if (b.childNodes[c].nodeName === "HEAD") { b = b.childNodes[c]; break } } d = b.childNodes.length } for (c = 0; c < d; c++) { a = b.childNodes[c]; if (g === "LINK") { e = a.href } else { if (g === "SCRIPT") { e = a.src } } if (e && a.nodeName === g && e.lastIndexOf(f) !== -1) { return true } } return false },
works as it is expected and the DOM Pollution that i described above no longer appers. Could you please confirm that this is issue in the loader js file and that it will be fixed in the next releases?
I have created a support case on your behalf with number CAS-108176-B6J0W6. You can find your active cases under Account - Support Activity in our website. Select your ticket and go to Development Issues tab to view the status of related bugs.
Let me know if you have any further questions.
