I am attempting to follow this example to get filtering on my grid. Using Razor I have it set up like this
@( Html.Infragistics().Grid<InstrumentList>() .ID("igGrid1") .Columns(column => { column.For(x => x.ProcessNo).DataType("int").HeaderText("Process No"); column.For(x => x.SubProcess).DataType("string").HeaderText("Sub Process"); column.For(x => x.Stream).DataType("int").HeaderText("Stream"); column.For(x => x.EquipmentCode).DataType("string").HeaderText("Equipment Code"); column.For(x => x.SequenceNumber).DataType("string").HeaderText("Sequence Number"); column.For(x => x.EquipmentIdentifier).DataType("string").HeaderText("Equipment Identifier"); column.For(x => x.Tag).DataType("string").HeaderText("Tag"); }) .Features(features => { features.Sorting().Mode(SortingMode.Single).ColumnSettings(settings => { settings.ColumnSetting().AllowSorting(true); }); features.Selection().MouseDragSelect(true).MultipleSelection(true).Mode(SelectionMode.Row); features.Filtering().ColumnSettings(settings => { settings.ColumnSetting().ColumnKey("Tag").AllowFiltering(false).FilterCondition("startsWith"); }); }) .ClientDataSourceType(ClientDataSourceType.JSON) .DataSourceUrl(Url.Action("GetInstrumentLists")) .Width("100%") .Height("700px") .DataBind() .Render()
I also have this listed at the top of my layout file:
<script src="@Url.Content("~/Scripts/jquery-1.5.1.min.js")" type="text/javascript"></script><script src="@Url.Content("~/Scripts/jquery-ui-1.8.11.min.js")" type="text/javascript"></script><script src="@Url.Content("~/Scripts/Infragistics/ig.ui.js")" type="text/javascript"></script>
I am getting an error '$.tmpl is not a function' from line 17683 of ig.ui.js. It goes away if I remove the filtering lines in the grid setup. Could it be because I'm using jquery 1.5.1 and the script is built on jquery 1.4.4? 1.5.1 is the default version that comes with an MVC 3 project. Any ideas?
For anyone who wants to know, I ended up finding a plugin called jquery.tmpl.js that solved the issue. Shouldn't this be included in the control install if it is required?
And no, it didn't matter that I was using jquery 1.5.1.
I replied to your original thread on stackoverflow:
http://stackoverflow.com/questions/7116068/javascript-error-when-filtering-infragistics-jquery-grid-control/7119048#7119048
hope it helps. Thank you,
Angel
Hello,Please let me know if you need further assistance with this issue.
Nope, Angel has replied to my question on the stack overflow thread.
