It is my understanding that the Datagrid can be themed based on CSS overrides.
It would be nice to have a bunch of basic examples out there.
Mostly, I think what most devs need to do is maybe adjust font, font size and padding around the column header and cells. There is a lot of wasted space on these grids.
Hello Matthew,
Thank you for contacting Infragistics.
As of right now you cannot apply CSS elements within the grid (columns, rows, cells individually). There are several style-related properties such as Background for changing the background-color on the IgbColumn directive.
eg.
<IgbTextColumn Background="Red" />
You can override the column's cells by using a TemplateColumn and hooking onCellUpdatingScript and in javascript override your cell's content. I would only do this if you are injecting your own custom dom element inside the cells.
github.com/.../App.razor
